Showing results for tags 'autocad civil 3d'.
LISP: Increase consecutive number & Object data to block attribute
BRIAM RAMON posted a topic in AutoLISP, Visual LISP & DCL
I would like to merge the lisps I show at the end into one, where the process is first ADDID.lsp and then OD2ATT.lsp If it were possible with your help to add a new functionality to addid.lsp and that is that when you copy the block name in the TIPO_SENAL field of the Object Data You c...- 1 reply
- lisp
- autocad civil 3d
Thing to check when borders come out with improper lineweights?
Oscar posted a topic in AutoCAD Drawing Management & Output
This is a mark up I got at my job. The guy claims its to thick. I have been using our standard plot style (pen Assignments) and I don't find anything wrong. What are some reason borders dont come out like you want them? -
I struggle understanding how to scale objects properly. I know how to use the command and all but I don't really see how my co-workers figure out the scale factor. I think they look at the scale on the drawing like a 1/4"= 1' and go by that when I bring in blocks or text. I guess I am looking for so...
