Showing results for tags 'autocad 2d'.
    • autocad 2d ×
Found 4 results
  1. Hello. I am using an old acad.lsp file with custom modified commands. After years of using it without any problems, it suddenly stopped working. This happened on two different computers with different versions of autocad (17 and 18) and without any software or windows updates. Au...
  2. I Have lisp for placing slope and arrow with polyline and i want enhance this to what i need mention in my drawing file..so i have attached lisp & sample drawing file . and also want to enhance lisp for select all polyline at once, currently lisp select on object at once. thanks....
  3. hi, i am using cad designcenter blocks for bolt and nuts what happened while dragging (whether i have done it or not) the nut size is 4 times bigger is coming i gone checked in the source file of design center it is ok there but when i drag i from the paletter it shows size more and the same compone...
  4. hi guys, this is my first query how to calculate man hours per drawing. whether based on size(a1,a2,a3,a4) , or by based on drawing.. some companies they are calculating based on sheet size...
