Showing results for tags 'autocad 2025'.
    • autocad 2025 ×
  1. Hello everyone. Please refer to attached for more information. I hope this is the correct sub for this. As the title suggests, I would like to pick two dimensions, add a user defined size to both individually (usually, but not always, the same dimension for length and width) and have it insert...
  2. Can anyone help? I'm using autocad 2024 and i need smart block feature which is available with autocad 2025, cmd name is bconvert.. Pls see this YouTube video if required
