Showing results for tags 'autocad 2014'.
    • autocad 2014 ×
Found 16 results
  1. I could individually select numerous individual objects then pan all around the drawing without losing the selected objects. Now, I can select various individual objects, with no active commands, and as I start to pan, without moving the selected objects off screen, I lose all the selected obje...
  2. Hi. I'm trying to create a block-based multileader style in ACAD 2014 LT, but I'm running in a weird color behavior issue. below is the block used as the base as seen in block editor : The issue arise with the hatch. I've been using a version without a hatch for a long time without any...
  3. OK, so I'm an experienced CAD user but have never had to do anything but draw by metes and bounds before, so I need some direction here. I am trying to draw the location of a proposed driveway in vanilla AutoCAD 2014 in such a way that I can bring it into QGIS and/or Google Earth and lay it righ...
  4. Hello! I am having an issue with a block that a college made in Autocad. It is a block that shows which xref's that are attached to the drawing. But for some reason, the text in the block is not visable for me, but the block works fine for my colleges. Do you guys have any clues about t...
  5. Hi All, I'm hoping to get some help in editing a LISP routine please. I have a LISP created by Charles Darling http://www.gilesdarling.me.uk/lisproutines.shtml which i'm hoping to get some assistance editing slightly to suit my needs better. I have a cable route which I am trying to cre...
  6. After I arrayed an object, the 'array creation' ribbon tab doesn't show up. This is the tab I want to fine-tune the array. But this is what I get:
  7. In the past I have always had two versions of AutoCAD installed on my system. One for straight AutoCAD work and the other for Archibus CAD Overlay work. Last time I did this I had AutoCAD 2010 and AutoCAD 2009 installed. Now that Autodesk has changed their educational licensing and our facilit...
  8. Hey guys is there an easy free way to convert a Gpx file to a Dxf file? I have some data points taken with a Garman gps unit, and I now need to get these point into AutoCAD 2014 Vanilla. I have used search engines to fine a solution, but everything I find either seems to old to work on my PC, or c...
  9. When I export from a drawing from Inventor 2014 to model space in AutoCad 2014, all my fonts change. I tried using a few fonts (last one being RomanS). The biggest problem is that when you print from AutoCad after exporting from Inventor, all the text is "hollow" and not filled in. Thanks for any...
  10. We have recently upgraded to 2014. Some of our plans created in 2011, when opened in 2014 have most of the objects missing in the paperspace tabs. This includes lines, polylines, blocks, ole objects, jpgs, and plain text. These are not xref'd items. A few members of our staff have LT 2014 and have o...
  11. Sooo, I recently got into the Middle School I wanted, and in that school we have this school subject where we do all of these 2D exercises, so I was wondering if you can post me some links or files i can use. Thanks in advance:):)
  12. My manager just asked me about AutoCAD 2014 and will consider an upgrade if he thinks it's worth it. Is there somewhere I can see an overview of the main differences between AutoCAD 2012 and AutoCAD 2014? I also remember a recent thread about some AutoCAD 'testers' that released some info to the...
  13. Good afternoon. I haven't used autocad since 2002. I am look for a good instructional video that will get me up to speed with regards to autocad 2014. I just downloaded the trial version of Autocad 2014 and I want to become proficient enough to be employable within the next few weeks. I have...
  14. Hello, when clicking on any object in AutoCAD 2014, I see always the same values in the Properties Window. No matter what I create or what I click on, I only see the same exact numbers which do not change at all. Have you ever had the same problem? Did you find a solution? Thank you very much for...
  15. Chasing around CAD forums left me with the conclusion that, at least up to AutoCAD 2010, there was no way to change that background in which we create models. Someone said that Autodesk knows better than the users so we have a choice between drab grey and depressing grey. I am using AC 2014 an...
  16. Working through Brian Benton's tutorial 'Quick Run Thru' I find that the 'Offset' command works differently from the way it is displayed. Command: _line Specify first point: Specify next point or [undo]: Specify next point or [undo]: Zero length line created at (3290.0000, 1250.0000, 0.0000)...
