Showing results for tags 'autocad 2013'.
    • autocad 2013 ×
Found 22 results
  1. I am a network administrator, I don't use the software. W7Pro x64, 8GB RAM, Optisys/AutoCAD 2013 working in telecomm infrastructure design. I have a user who can no longer "snap to intersection" as he describes it, this makes it difficult for him to keep lines straight. I've looked through the...
  2. hello! Sorry if I missed a threat about this subject, but I've encountered the next problem: While working on a 3D model, during change of view or visual style, some solids disappeared and appeared back if I went back to previous view. But when I opened my model this morning, a lot of solids...
  3. Autocad 2013 in model work area , I am having a problem with selecting blocks from the pallet and placing them on the drawing. most were set t0 place at the selected point. how ever i don't know where to begin it will place them at x,y but not at z, ends up out of frame. in front view i place the bl...
  4. Sorry for my bad english. I have autocad 2013 map 3d since 2 months, and there is a drawings-midpoint on the display/screen, how can I remove that 'wheel'?
  5. Hello all, First time poster here. I've got a large AutoCAD drawing compiled with about 4 different layers. Now I want just a section of it, and nothing else. I was wondering if it's possible to crop what I want (inside the white box area) and delete the rest. If so, which tool do I use? I'm...
  6. Hi All, This is something I've waited for since December 2010 when I first learned about it: http://designplaygrounds.com/deviants/about-generative-design-platforms-by-mark-loomis/ http://labs.autodesk.com/utilities/designscript This plug-in to AutoCAD does the same thing that Grasshoppe...
  7. I can't find much info in this so thought I'd ask here... I have a custom CUIX file as our enterprise menu for our CAD standards and settings and with it have MNL file to auto, demand load LISPs. It works fine for me as an admin but not for others. I've looked into the problem and it seems to be...
  8. i installed it a 2 month ago, and it was fine and everything. i even used it but, after a while of not using it, it didn't work. it is running but, a box pops out saying "the security system is not functioning or is improperly installed", and then it disappears... pls help ToT i don't know what...
  9. Hi Guys, I have been using AutoCAD for some time now. I have always been trying to stay away from X-Refs as I do not understand them fully. But in the current project im running I have to upload a .dwg into a program, but the catch is, the drawing MUST NOT have any X-refs. Now, in the folder str...
  10. Hello everyone, I'm new in this forum page, I'm tired of search something that could help me solving my problem but nothing's worked yet! The problem is that I had installed the Autodesk 2013 in my PC for the first time ever, everything was perfect! It worked really cool and since a month a...
  11. Hi, I hope you can help. I have created buttons which create custom properties in the DWGPROPS. I would now like to add another custom properties which shows the Current Time (not to be updated). Can this be done?
  12. Hi, I have this 3d file of mine (which i have worked so hard for it), and it's size has increased to 240 Mb's! I assume this has happened due to forced closings and the backup files ... i have already deleted them... but it didn't help. i ant even copy my model into a new work space. please... h...
  13. Hi, the problem I was facing (and still facing) was that I use my mouse middle button (scroll) as pan when clicked, But it poped out menu for snap overrides, then I resolved this issue by MBUTTONPAN variable by setting its value to 1. Now when I start a new file or a new session it reverts back to...
  14. Is it possible to use the viewport on one page to show the paper space of a different page?
  15. Hi, I'm trying to delete a unused layer. But when I do that I get the following error (see attachment). I googled a bit and figured out that the LAYDEL command might solve my issue, but as I'm using Autocad 2013, that's not possible, as it doesn't have this command... Any id's how to solve this...
  16. Hi, I'm an Autocad Architecture user (the 2013 student version) and I was wondering if someone can solve a mystery for me. In Acad's Material library there are some Water materials you can choose from such as Swamp, Swimming Pool, Tropical etc, but I can't figure out how they're supposed to be used...
  17. LearningCad
    3d to 2d modeling
    Hello this semester i took Computer aid grafting design and i am using autocad for the first time .. until now for being the first time using autocad i think im going really well and i have learned a few things and i feel good about that but now i am struggling to pass this course and it is very imp...
  18. Hey everyone, I have recently come across a new issue I'm having with my Civil 3D 2013 when converting my DWGs to DGNs. It seems that if a DWG is saved in 2013 and then converted to DGN using Microstation V8i (or exporting from CAD) any complex linestyles come into the DGN with "?"'s where the...
  19. When trying to orbit while pressing the mouse wheel & holding shift nothing happens. I have looked into CUI and everything is set up correctly under mouse buttons. Clicking on the navigation wheel allows me to orbit but using shift and mouse is so much quicker. I have just upgraded to AutoCAD 2013 p...
  20. I just installed Autocad 2013 as a trial to test it out and I like it. I noted two flaws in my installation and I was wondering if it's just me/my hardware or if somebody else noted the same behavior. On the ribbon (affects all panels and work spaces) as well as in tool tips the last lett...
  21. Hello all! Just converted to mac and have installed autocad 2013. I am quite shocked to find no option for 'smooth display' or anti aliasing for 2D drafting. Am I missing an option, I am very new to mac! Thanks for your help. Mike
  22. Hi there, I am using Autocad LT 2013. I wish to use Autocad to draw subdivision lines and need to overlay satellite imagery (Google Earth or Google Maps) in tandem with Garmin GPS waypoints taken in the field. In the 'type a command' ribbon, when I type in 'GEOGRAPHICLOCATION' and select...
