Showing results for tags 'autocad 2011'.
Is there really an option to change my Additional Text's Color? I can't find any option to change color, currently it is sent to default white but I need to change it to cyan.
- 1 reply
- prostructures
- prosteel
How To Update Dimensions To Block Parameters
Walker140 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello, I have created a new .dwg file. Within the drawing I have created a block that updates when I change the parameters. Currently when I change parameter lengths the dimensions do not update to match the length of the block. Is there anyway to add dimensions that will update within the origi...-
- dynamic
- dimensions
creatre Mleader in Pspace leader start with edge of 3d solid/3d block
ramanusu posted a topic in .NET, ObjectARX & VBA
Hi everbody, I need a help with Autocad 2011+ with VBA (Visual Basic for Application), I want to creatre Mleader in Pspace leader start with edge of 3d solid/3d block. Which classes should I use? Thanks for helps.... -
Hello everyone, I'm writing because I need to disable the dynamic input in AutoCAD. It's irritating to me, because I'm more used to a much older version of AutoCAD. I just found this forum while searching through the internet and this is my first post here. Upon searching through the inte...
- 11 replies
I have developed a handout for my students and graduates I thought I would share here: www.KishwaukeeCollege.edu/cad Hope it helps our cause.
Recently starting having this problem. 1-2 months ago it was not a problem. I am not aware of any system variables being changed. When using the WBLOCK command, no thumbnail preview is being saved with the block for previewing in Windows Explorer. I have check the RASTERPREVIEW system variable i...
- 21 replies
- thumbnail
- rasterpreview
Is it possible to export a drawing to pdf without opening a drawing where AutoCAD is installed. I want to write my own code using AutoLISP or VB.Net (and not use any existing third party utility) because I have some specific additional requirements. Any guideline would be helpful. Is Obj...
- 3 replies
- dwg to pdf conversion
- autocad 2011
Every time I get close to an object (anything in my drawing), my curser snaps/or lags on the object for a second. I have all my snaps off, thought that it would be the magnet settings in the AutoSnap but it is not. Have never noticed this problem before.... Anyone know of more snaping settings it co...
First time in this forum. I have a rotate problem. I am going from AutoCad 2010 to 2011 and I haven't been able to change all the setting in 2011 to match my usual fun loving workspace. (Anyway) I need to rotate an object in 3D space and 2011 isn't allowing me to do so. I can rotate from the top vie...
- 6 replies
- autocad 2011
- 90 degrees rotate
hi there, anyone can help me on how to distort the reflection. as you can see the reflection here is very perfect, is there a way to distort it. the reflection of tiles on .45 pistol, it looks like the pistol is transparent. if maybe i can distort the reflection it would make it more realistic. than...
hi there, anyone here knows how to distort a reflection? as you can see here in my model, the reflection of tiles make the .45 pistol slide somewhat looks like transparent (looks like illusion too). i need to distort the reflection but dont have any idea. thanks. by the way still in process...
LISP for changing block references to circles
jmsimpson posted a topic in AutoLISP, Visual LISP & DCL
I have over a thousand block reference points that I have imported into AutoCAD. I would like to convert these block reference "crosshairs" into circles. I want the diameter of these circles to correspond with the elevation numbers from the data set. If you're wondering why I want this, I am trying...- 15 replies
- lisp
- autocad 2011
I have an excel file with several thousand lines of data and they all have UTM coordinates attached to them. I would like to have the data mapped out as points once imported. Is there a way to import this data into AutoCAD without going through ODBC? I have also imported the data into Access so retr...
- 10 replies
- autocad 2011
- arcgis
How do you edit the 'Turn Slope' of an AutoCAD 2011 helix? The default value is 0.000 and it offers the QuickCalc to edit it, but I haven't figured out how to do so. I want a turn slope of 32 degrees but I can't change the 0.000 value. Please see the attached file for more information. Any h...
- 7 replies
- helix angle
- helix
Hello, I'm the Sales Operations Manager for a Design House \ Manufacturer. We currently use AutoCAD 2011 to provide line drawings to our customers, but render requests have become more and more common. Our Marketing group employs an Artist who uses 3DS Max for renders, but our company's Pres...
Hi! I want to import default templates (Title Blocks) with in Auto cad. Is there any option ? How to proceed? Thanks in advance Atul
- 3 replies
- templates
- autocad 2011
I only have a tiny macbook right now, and I need a more powerful desktop to run programs like AutoCAD 2011 (3d), SketchUp, CS5, and eventually Revit, and 3ds Max. I am a student, and I don't have ton of money to spend, but I do want something that will run these programs smoothly. I was thinking abo...
- 9 replies
- photoshop
- illustrator
Hi, the interface in AutoCad 2011 becomes messed up randomly. (see pic) The program has worked fine until now. Anyone have some ideas on what to do?
:unsure:Dear Forum, I have successfully downloaded the autocad mac as a student license for 3 years, however when trying to open for the first time it bounces up and down four times and then goes flat, try it again and the same thing happens? Can you help. Running graphics card ATI Radeon graphi...
I have installed autocad architecture 2011 and have tried to switch to classic mode workspace but this option does not appears in the menu as you can see on picture.... can you help me ?? Thanks in advancing
