Showing results for tags 'autocad 2008'.
    • autocad 2008 ×
Found 4 results
  1. no cui file is loaded when i open autocad 2008. when i use the 'cuiload' command there is nothing in the 'loaded customization groups' list. i browse to the default cui file i want to use (acad.cui) and click 'load'... and then NOTHING happens. i cannot load any cui file from any location into my lo...
  2. Good day! At work last week damaged the server. Today it was restored, but when you open an AutoCad file that lay on the network, gives the message «Drawing file is not valid». Before it is said that this file or is used, or only for reading. The file is not zero. Has the same size, as before crash...
  3. I need to cut some flat veneer using a laser machine, like making a jigsaw puzzle. The laser operator needs a drawing in the .dwg format. I will be drawing a 2d shape using a photograph in the background to copy. I need to make the shape cut up into sections so I can assign a different bitmap...
  4. I have a 3D Autocad 2008 Mechanical drawing and I need to rename some blocks. The thing is I can use RENAME in order to change their name but when I do that, multiple blocks are renamed and I don't want that. I want to be able to rename each one of the block, individually. Is there any way...
