Showing results for tags 'autocad 2007'.
hi all i have inserted a table in a drawing. after i re open the drawing the table is not visible. when i explode the table it is saying that 1 external reference. please guide me how to see the table in the drawing and how to explode this type of entities. i am here attaching my drawing. p...
AutoCAD 2007 crashes when I try to convert to PDF
Danarchi posted a topic in AutoCAD Bugs, Error Messages & Quirks
Hello! I am new here and here's my first question: After not using AutoCAD for 4-5 months, I don't know what happened, but now when I tried to convert my DWG to PDF (that I've done successfully a million times in the past) it crashes and the program shuts down. I 've tried doing it both ways: plot.... -
How to do isometric view and top view in autocad?
gen_shao posted a topic in AutoCAD Beginners' Area
im doing both isometric view and top view of a floor plan in a single paper at the same time. the problem is ..when i change the view to isometric.. the drawing that is intended for top view changes to isometric view also.. how can i change the view of a single object to isometric isolatedly,,...- 6 replies
- isometric
- autocad 2007
import coordinates of a 3D model to autocad
green77park posted a topic in AutoCAD Drawing Management & Output
HI Freinds Any one can help me on my model I try to Draw Transmission Tower with Autocad and I have the coordinates of joints of this model on notepad I try to import it to autocad with many way it not succed any one have an Idea how can I do this and drawing the members (line between joints) easil... -
I need to add 1/8" gaskets to flanged piping. My primary reason for doing this is so I can get the correct length for the pipe. I was planning on simply pulling the flanges back and 1/8" but when I do that it stretches the pipe. Is there a way to detatch pipe from fitting or fittings from fitting...
- 7 replies
- gaskets
- fab-drawings
Same Viewport - Multiple Drawings
tigerlilygirl posted a topic in AutoCAD Drawing Management & Output
I have 5 drawings that all have the same model (basically a topo map of a 2 mile radius) but each have unique info, i.e. monitoring well locations, utility info, etc. The client wants a zoomed in view of a 1 block radius and I need all 5 drawings to have an identical zoom. How do I adjust my viewpor... -
When I go into AutoCAD and start working, a crosshair shows up like normal but there is also the windows cursor. It follows the crosshair wherever I drag it. Does anyone know why this is? I am logged onto my work computer remotely and I am on my laptop with a wireless mouse connected. Thanks!
- 2 replies
- crosshair
- autocad 2007
