Showing results for tags 'autocad 2006'.
    • autocad 2006 ×
Found 4 results
  1. guusdehart
    vba drawing polyline
    Hi, My VBA project reads coordinate file from field measurements of topographer and builds via some routines two classes: AllPoints (x,y) and AllLines (from x,y , to x,y). Seperating real points from reference points. I cannot seem to get a way to kick of the drawing command. Anybody some ideas?...
  2. dkelly
    Toolbars
    I recently moved my AutoCAD 2006 from computer one to other and the default toolbars didn't load to my drawing when I opened it. The "View" pull-down menu did not display and when i right click in the existing toolbar nothing happens. Previously, the right click in the toolbar would give me the "V...
  3. Well i have a homework for the university , im working in AutoCAD 2006 , so the project is that, i have a pdf with contours of an area, i have to rasterize it as a jpg picture, pass it to AutoCAD (i have done this so far..) and then i have to find the X , Y and Z coordinates of some points in the pi...
  4. I'm thinking about using sheet sets to manage projects better and so I can use fields in my title block. I want to use the sheet set manager to add sheets to my plans but every time I create a new sheet it creates a new .dwg file. Is possble to just create a new layout in the current drawing?
