Showing results for tags 'auto dimension for polyline curved'.
  1. Hello Everyone, I made this lisp using google and I tested it's working >>> but stop suddenly not continuing the loop I made a lot of searches but found nothing to fix my issue This Lisp selects only Polylines with ARC segment and puts ARC Dimension I have another Lisp to make dimensions to normal polyline and I will combine it ... can you help to fix the issue in this lisp, please if you can make a favour and make a lisp to dimension all polylines ( normal & curved ) , you will save me from losing a lot of time. Thanks (defun c:test () (defun *error* (msg) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (vl-load-com) (if (setq sel (ssget '((-4 . "<AND") (0 . "*POLYLINE")(-4 . "<>") (42 . 0.0) (-4 . "AND>")))) (progn (setq i 0) (while (< i (sslength sel)) (setq MyEnt (ssname sel i)) (setq mid (vlax-curve-getPointAtDist MyEnt (/ (vlax-curve-getDistAtPoint MyEnt (vlax-curve-getEndPoint MyEnt)) 2.0))) (command "_.DIMARC" MyEnt mid mid) (setq i (+ i 1)) ) ) ) (princ) ) Lisp.lsp Test DWG.dwg
