Showing results for tags 'attribute value'.
    • attribute value ×
Found 9 results
  1. Hello, can anyone help me please with this topic? I have 9 layouts. I've inserted the same block to each layout. I want to change some attributes (the title of the drawing inside block) for each layout out of those 9. The Layout name is variable according to the number of project wh...
  2. Hi! I am just new here and also a newbie in doing lisp routines. I was wondering if there is an autolisp that could possibly delete a text value of a specific attribute text inside a block of a block. I don't want to totally delete the attribute, just the value. I already tried several examples on t...
  3. Hi all! I would like to give (notedit) a tag attribute value to existing multiple blocks. The attribute is defined as ‘SIGNCODE’ but the value of thisattribute is currently empty.Also I need to givedifferent values to the ‘SIGNCODE’ for multiple blocks in the same file. I am using AutoCAD 201...
  4. Hi everyone, I am a software developer , i program in C# C++ and Java, but lately i have been given a task to help out our engineering department to write some code + script to fix cad prints which they have issues with. our problem is we use a third party application which generates an AutoCad...
  5. Hi All. I am trying to achieve the following: for example... in 100 floor plans there are blocks that have certain attribute values. i want to be able to create a script/lisp that will find all blocks that include a certain piece of text ie "window" in the attribute value and change the block...
  6. I am trying to simplify my companies current process of updating BOM. We currently type all part dimensions in an excel spread sheet to get the weight of different group of materials. I wanted to make a lisp that after changing one or many of the dimensions in the BOM blocks it would recalculate t...
  7. Morning Everyone, I've just won a fabulous project with a very well known supermarket producing phasing drawings for their new store fit-outs; I receive their drawings in DWG format with as you can imagine thousands of blocks detailing the shop fixtures. Each blocks contact a minimum of 5 attri...
  8. Hi guys, I'm a new member as you can see, but i've been coming here for many years to find information about lisp. I've done a thread search and haven't located a solution to my issue. I am self taught, so there is only so far i can go without getting the experts involved. My question (i thi...
  9. The Question: Can Visibility States be changed by an Attribute Value instead of the drop down arrow? The Situation: I am building an annotative block that the user wants to change appearance (ie different hatches inside a circle) based on an attribute value (1,2 or 3). The attribute is invisibl...
