Showing results for tags 'attribute text'.
    • attribute text ×
Found 4 results
  1. Hi, is there a way to save my drawing with its name in a directory by using a Attribute value. Example: Drawingname: test.dwg blockname: TitleBlock Attribute: SF:WE Attribute-Value: test2 And it should save the drawing in: C:drawing/test drawing/(attribute-value)/... but...
  2. I have a block with an attribute definition. The text style of the attribute is set to SA-Text. In a new drawing, with the SA-Text text style already defined, the text style of the attribute reverts to Standard when the block is inserted. Any ideas?
  3. Hi This is my first post in this awesome forum:). I’ m newbie in drafting Kindly help me with a lisp program. That Asks the user to select various texts in the drawing Places an attribute text over the selected text without replacing them Makes an attribute block with that att texts...
  4. Hi there, Having a very annoying issue regarding attributed text updating when reinserting a DB. I have text override in a dimension, inserted a field into the text override but whenever I reinsert the block and change the values, the text does not update. Thoughts?
