Showing results for tags 'attribute reference'.
    • attribute reference ×
  1. Hi! I would like a macro which will add a text attribute from an x-ref file to another block attribute which is up to 1.5m around the x-ref element. example: Attribute block: WF-PC-L2.0-095 X-REF attribute: L2.0-0368 I' d like to add L2.0-0368 to WF-PC-L2.0-095. The distance between the 2 attr...
  2. Hi there, I´m developing a little interface for AUTCOCAD at the moment. I use Visual Studio 2010 and ObjectARX 2012 with C#. The interface should be able to edit specific blockReferences and their attributes. I´ve got two special kinds of blocks which I want to edit. Now I´ve implemented a command...
