Showing results for tags 'attribute field'.
Block Insert, Center and Auto Fill Attribute values, by clicking two points input
jfklimek posted a topic in AutoLISP, Visual LISP & DCL
I'm having trouble finishing this LISP. Can anyone help me out. The command line is telling me the command I'm entering 'roomtag' is unknown. It's probably something little but I can't seem to figure it out. Please help out if you can. Thanks! ;;;Place Room Tag in Middle of Room and Auto Fill...- 11 replies
- block insert
- attribute field
Link attribute value to another attribute value
doru10 posted a topic in AutoLISP, Visual LISP & DCL
Hello all, I have two blocks with different attributes. want a connection between the two blocks especially in the areas marked in yellow. node when the value changes from 56 to 101 to make update the labels. Attach an example. best regards Sample Annotation Pipe for link.dwg- 18 replies
- link
- hyperlinks
insert a formula in the block attribute value via vba
aleair posted a topic in .NET, ObjectARX & VBA
Hi everybody, I'm new with autocad. Actually it's my first time I need to write a VBA procedure for autocad. That's the reason why I'm posting this thread. I have blocks with attribute. In one of this attribute I want to insert an expression that calculates a polyline area. Doing it manu...
