Showing results for tags 'attribute edit'.
Hello, I am new to AutoLISP world. I am trying to write a code which will edit attribute in incremental numbering with each click on attribute. The easiest way command for it is "ATTIPEDIT". But I failed use ATTIPEDIT in LISP. Pls help to run this code: (defun c:DTAG () (princ "\n AUTOMAT...
- 5 replies
- increment numbering
- attribute edit
Morning Everyone, I've just won a fabulous project with a very well known supermarket producing phasing drawings for their new store fit-outs; I receive their drawings in DWG format with as you can imagine thousands of blocks detailing the shop fixtures. Each blocks contact a minimum of 5 attri...
- 13 replies
- attribute value
- attribute edit
Global Edit: Block Attribute's Rotation BACK to match Block's Rotation
ORgrown posted a topic in AutoCAD Drawing Management & Output
using AutoCAD 2009 (vanilla) I got too smart for myself today in bringing an old drawing up to current standards... Everyone seems to want their block attributes to be zero - I have blocks where the attributes are best when they match the rotations of each blocks. I have an old drawing tha...- 2 replies
- global attribute edit
- attribute edit
