Showing results for tags 'attribute definition'.
    • attribute definition ×
Found 4 results
  1. Hello all! Let me first say that I've been looking through some of the threads on this forum and am blown away by the knowledge and creativity some of you possess. It's ridiculous the things you guys are able to do with AutoCAD. With that said, I'm hoping someone can help me solve a difficul...
  2. Hi all, could you please give me a solution to update block attribute value in multiple layouts with out changing the existing values. eg: Tag DT3 Value "part-01" I need to edit the value as "MEP Part-01" The multiple layout have different numbers. So I need to add "MEP" to all layouts....
  3. Hey everyone! First time poster, long time user. I run Autocad 2010LT at work, where I do fire alarm drawings. I've been trying to create a dynamic block (sort of a one stop-shop) for my wiring diagrams, and wanted to include device text with it. My question is, is there a way I can create...
  4. I'm currently working on a script to (semi) automise drawing rail constructions. This is going fine, except for one very odd issue. I'm quite a beginner, so please bear with me. I have to insert a block with an attribute. Since I want to avoid using ent* commands, I wrote the script using (comma...
