Showing results for tags 'assoc 10'.
  1. SOLVED! I've made several line using (polar Point1 Ang Distance). How do i get assoc 10 and assoc 11 to work without selecting the lines. Or maybe a routine that can create a list (append) when a line is done so i can retrive assoc 10 and 11 later. FYI, the line making is in the (WHILE section so the routine will keep making lines. Thank you.
