Showing results for tags 'assembly drawing'.
    • assembly drawing ×
  1. Hi, I was asked to create an installation/assembly drawing of a gear motor that will be installed on the side of a machine. I have some few references like the machine manual. I'm planning to trace the installation on the manual.This is my first time to create installation drawings and not quite...
  2. I am trying to speed-up dimensioning of an assembly drawing (DWG) in Inventor using iLogic. The assembly contains parts which have parameters which I would like inserted into dimension text. I can achieve this manually using the Edit Dimension / Format Text dialogue boxes to select the part paramete...
