Showing results for tags 'arrow heads'.
Hi all, First poster here! Thought I would start of with something small. Does anybody know how to create a (new) Quick Leader command that has a DOT arrowhead default? I have tried to play around with the command macro (^C^C_qleader) but to know avail. Any help will be greatly appre...
- 4 replies
- command string
- command
What are arrowheads in AutoCAD composed of?
toastonrye posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I spent most of my work day searching, no luck. My issue is we have a series of drawings with drill hole layouts, that are suppose to be imported into Vulcan. Tried various DWG/DXF options to export. All the lines, text, co-ordinates come in perfect except these arrowheads. They are importan... -
Hi, I am using autocad 2008, I am having a problem with dimensions arrow head (Solid dots) when ever i give dimension the arrow head doesnt appear as solid fill, it shows radial lines in that circle, whereas in some files it does appear correctly (see the image). Do i have change any value f...
- 3 replies
- solid dots
- arrow heads
