Showing results for tags 'array in dynamic blocks'.
    • array in dynamic blocks ×
Found 5 results
  1. Hello all! Let me first say that I've been looking through some of the threads on this forum and am blown away by the knowledge and creativity some of you possess. It's ridiculous the things you guys are able to do with AutoCAD. With that said, I'm hoping someone can help me solve a difficul...
  2. Hi This is my first post on here, I'v had much benefit over the years with queries however I cannot seem to find one that will help me this time. I'm unsure as to whether this is a glitch or an error in the block? I need a panel drawing that can be stretched both in height and vertical. Alon...
  3. I have the following block where I have successfully inserted stretch action (no limits) and array action (limit 20). I need to display the array count number next to the block so that I don't have to count the aisles every time I have to use the action. Dynamic Array Count.dwg
  4. How can we have an array with variable distance between columns in dynamic block? I have an application where I used a lookup table for a stretch action, I want the array distance to change when I change the value in the lookup table.
  5. My dynamic block is an Index form that has three attributes that need to be copied down as I "stretch" the block. This index needs to have anywhere between 4 and 64 entries. My knowledge of making dynamic blocks is not extensive, I have been doing it for a while, but nothing too complicated. I...
