Showing results for tags 'array (3d)'.
    • array (3d) ×
Found 4 results
  1. Hi All, I need to design a 'stencil' of sorts - but it just needs to be an array of circles separated by a constant distance. its an array of 200 micron diameter circles separated by a distance of 500 microns each (between centers). Its super easy to make this array, but when I try to 'pull' it i...
  2. Hello, I am trying to array a 3d block along a 3d polyline made up of straight plines. I align the block to the end of the endpoint on the 3d polyline ie the path. use array path command.The block does not align properly around the path. I have tried the z direction and selecting no. Attached i...
  3. Hi All, I need to design a 'stencil' of sorts - but it just needs to be an array of circles separated by a constant distance. its an array of 200 micron diameter circles separated by a distance of 500 microns each (between centers). Its super easy to make this array, but when I try to 'pull' it i...
  4. Hi All, I need to design a 'stencil' of sorts - but it just needs to be an array of circles separated by a constant distance. its an array of 200 micron diameter circles separated by a distance of 500 microns each (between centers). Its super easy to make this array, but when I try to 'pull' it i...
