Showing results for tags 'area value'.
    • area value ×
Found 5 results
  1. Dear members, Any lisp program or trick to make a area table From a plan. I want a area table with plot number text along with area . I will select all at time, the automatically generate area table. Please See the attached image. AREA TABLE...
  2. Hi Everybody, Via the command area it is possible to retrieve the surface area of a solid body (Acad3DSolid). Unfortunately the area it is not a property of a solid body so I'm haveing difficulties retrieving the surface area (which I want to write to an excel file). I've tried to explode the s...
  3. Dear all; The properties not showing the hatch area of specific hatchs I attach the cad file thanks Romano cad tutor.dwg
  4. Hi! I would appriciate if someone would help me soloving this problem. As the first picture presents: 1.Only some of the quadrangle are being crossed with two red lines 2.Numbers, quadrangles and red lines are in separate layers I need to do the following thing: 1.Make sure that all quadra...
  5. Hi, I am in need of a lisp to do the following Find the individual area of poly line in layer 1 & Layer 2 Multiply the area in layer 1 by a factor 3.1 and Place text within polyline Multiply the area in layer 2 by factor 4.1 and Place text within polyline Sum of text as alert message...
