Showing results for tags 'area split'.
    • area split ×
  1. Hello, I need one help to do a LISP that can execute it: get one irregular area, and split it according a specific aredea defined, like, 100 m², and I need to split it in 25 m² (I know that it will result on 4 parts of the first one, but how do it?), can someone help me, thanks a lot. José R...
  2. i want to modified "area" command. see below picture. Click the first point. Click the second point. Click to third point, moving the mouse pointer along the line, the green part of the area, showing the edit is a must.
  3. how to divide a polygon into 3 equal polygons (same area or we known area)? I wanted to divide the polygon shown in the screenshot below into equal 3 polygons (with same area), but I couldn't figure out if these is some commands or workflow to perform this issue is the "trial and error" is...
