Showing results for tags 'area command'.
Hatch area problem!!!
Gentile Romano posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Dear all; The properties not showing the hatch area of specific hatchs I attach the cad file thanks Romano cad tutor.dwg- 4 replies
- area definitions
- area command
Hi every body , the lisp named CAR is a lisp routine to calculate the area of any entire polygon drawn in AUTOCAD. How to use : 1- Run the Autocad. 2-Load application named "car" or directly drag it into the autocad. 3- the command for the lisp is " car " enter 4- select the polygon u wan...
Want to calculate area by selecting the points in sequence for a closed poly line. I had done it before with no problem. Now it doesn't show any result. After selecting last point (one before the first point) and hitting ENTER to make a closed area, it just returns to command prompt with nothing...
