Showing results for tags 'area calculation'.
AutoCAD Super Hatch Area
sidhu412 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello, Is there anyway to calculate the Area of a Superhatch in AutoCAD? Thank you, Regards, Sidhu- 2 replies
- autocad
- area calculation
Hello! Does anyone know a routine that enables provide real-time the sum of areas of rectangles as you draw consecutively?
No Area Value for Polyline / closed polygon
dal-designs posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Ok, so this pesky polyline won't give me an area. I found a topic on the Map 3D forum that had a couple of suggestions, but I'm using vanilla AutoCAD 2014. As you can see by the image, the area value for this polyline is missing. I've tried flattening it (as there is a survey attached with 3D p...- 10 replies
- closed polyline
- area calculation
LISP File - Count number of blocks, calculate area within block
pholt posted a topic in AutoLISP, Visual LISP & DCL
Hi all, I'm hoping you can help. I require a lisp file that can count the number of blocks in a drawing and calculate the total area of say a polyline that is in each block and plot it in a table format? Can anyone point me in the right direction please? Thanks Peter- 3 replies
- lisp files
- count
Finding area of curverd balconies
atulkumarengineer posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
How to find area of curved balconies ? I follow the process: Inquiry>Area. I am able to select the rectangular area but how to select the curved semi-circular area? -
Hatch area problem!!!
Gentile Romano posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Dear all; The properties not showing the hatch area of specific hatchs I attach the cad file thanks Romano cad tutor.dwg- 4 replies
- area definitions
- area command
I created over 100 parcels in Civil 3D 2013, none under 9000 SF. After saving and closing the file, I opened it the next day to continue and all 100 parcels show 0 SF and 0 acres, yet the parcel segments still show as created. First off, WHY?! And secondly, how do I rectify the problem? Anyone e...
- parcel
- area calculation
Parcel areas change after closing file
Screech_Nelson posted a topic in AutoCAD Bugs, Error Messages & Quirks
I created 100 parcels in Civil 3D 2013, none under 9000 SF. After saving and closing the file, I opened it the next day to continue and all 100 parcels show 0 SF and 0 acres yet the parcel segments still show as created. First off, WHY! And secondly, how do I rectify the problem? Anyone else had...- 2 replies
- parcel
- area calculation
