Showing results for tags 'annotative text'.
    • annotative text ×
Found 5 results
  1. We're looking at implementing multileaders instead of quleaders in my office, and so I've been tasked with figuring out how to do it (being as I am the least senior, most peon-ish person in my department). I've messed with them before, so I mostly have it figured out. There is one thing tha...
  2. I'm wondering if there is a way that you can have a non-rectangular border (circle, ellipse, hex, etc) around text in a multileader. I only see an option for a default rectangular border under multileader options. I tried making a multileader with a hex drawn around the text, anchored at the...
  3. Has this ever happened to you? You have a plan at two scales, let's say 10 ft and 20 ft. You use annotative text because you need the same labels on both plans. You create a piece of text, no problem. You have the scale set at 20 ft and you rotate the text. When you go to 10 ft, the text has not...
  4. Hello, My mtext and multileader styles are created to be "annotative"; however, they didn't have a consistent size through all my different scaled viewports. When I drew them on my model, I added the scales needed, but on the viewports, the only objects consistent in size were the "Drawing Title...
  5. I been trying to figure out a way to make my Annotative Text to be vertical. I need them for Ductwork plans at work and they seem to be locked on horizontal some how.
