Showing results for tags 'annotation scale'.
    • annotation scale ×
Found 8 results
  1. I am creating a template drawing but while making this drawing I was working on two different versions of AUTOCAD (2012 & 2013). I have prepared my title sheet block but there are two scales in the drawing and I want only one i.e that is 1:1 but somehow there is one more scale which I am sure is com...
  2. I have a survey xrefed into a site plan. In the survey there is a multileader that needs to appear at two different scales, so I made it annotative. The same multileader sits on top of a hatch (which is in the site plan), so I gave it a background mask. At 1"=20', the larger scale, I can adjust...
  3. This is just a general question about annotative text, something I've noticed as we transition from 'each scale has its own text-dimension layer' to 'annotative'. I'm still a bit confused by the relationship between annotative scales in both DIMSTYLE and STYLE, and viewports, and actual plott...
  4. Hello Is it possible to code a custom linetype, so that it only follow certain annotation scales (eg. 1:100, 1:200 1:500) and so that it just appears as a continuous line below and above these certain scales? The solution should work even when the drawing is used by others and apply to both modelp...
  5. Hello, My mtext and multileader styles are created to be "annotative"; however, they didn't have a consistent size through all my different scaled viewports. When I drew them on my model, I added the scales needed, but on the viewports, the only objects consistent in size were the "Drawing Title...
  6. I am little new to autocad. I was finishing up my autocad project I noticed that the little arrow next to the annotation scale on the bottom right corner of the page was gone. The little arrow shows a list of scales in autocad so you can properly scale your drawing. Does anyone know how to bring...
  7. I am little new to autocad. I was finishing up my autocad project I noticed that the little arrow next to the annotation scale on the bottom right corner of the page was gone. The little arrow shows a list of scales in autocad so you can properly scale your drawing. Does anyone know how to bring the...
  8. Hi all I am going through my viewports properties, changing the annotation scales that for some reason are different to the viewport scales (why you would want a different annotation scale i dont know) does anyone know how when i make a viewport, with a certain scale, i can have it that the ann...
