Showing results for tags 'add text footage'.
    • add text footage ×
  1. AutoCAD Map5 Hoping for a routine (or two or three) that will: 1. Convert all Lines/LWPOLYLINES/etc to Plines (no object data on the layers I need converted) 2. BREAK each Pline at the Insertion points of EVERY instance of two different blocks that are inserted along the lines. 3. Insert TEXT...
