Showing results for tags 'add leader'.
    • add leader ×
  1. Sometimes, all of my dimensions change properties, displaying as if the dimension style is set for "move text, add leader", even though it is not. When I check the dimension style, it has not changed from "FIT/Text placement/Over dimension line, without leader". There are also no overrides. This...
