Hi Inventor passionists,
I would like to use constrains on axis(es), plane(s). For example using coincident button for a line to X axis (to sit the line on that axis). (Or dimension 0mm alternatively.)
But,...
the constrain does not recognize axis(es) and plane(s), even I make it/them visible.
Or is any other function button exist to sit a line or origo of a circle on an axis?
And how do I set same height? For example two lines or origo of a circle and a line etc.?
Thanks.
