Showing results for tags 'acad 2015 error'.
  1. Found this a problem with Acad 2015 - if you get this error go into your code and look for 'mapcar' then within that look for 'command' and change to 'command-s' (if plst (progn (mapcar '(lambda (X) ;turn layer on (if (> (cadr X) 0) (command-s "._-LAYER" "_ON" (car X) "") );i );l plst );m );p Hope this helps some people as it was hard to find
