Showing results for tags '3d to 2d'.
Hi, I'm looking to make a script, lisp or batch sort I could take all the 3D drawing from a file and convert it to a 2d drawing. I've tried a lot of thing like "flatshot", "outbounding", "flatten"... The best result was definitely with the "Flatshot" command, but it cannot be use as a scrip...
i have a drawing of tower in 3d, i want to put all the drawing in 2d only so that i can trim some part of the lines, is it possible to put the 3d in 2d in one level only, i mean one axis. i hope someone could help me. thanks
Can you create a mechanical drawing from a 3d drawing?
peregrin8r posted a topic in AutoCAD Beginners' Area
Hi. This is my first post here. I am self taught on acad 2008, and have created a complex 3d drawing over the last year or so. But I need it to be represented in a mechanical drawing. I tried flatshot, but this is not true to form. Is there a way to do this? (an easy way)
