Showing results for tags '3d solids'.
Dear Members! Problem part I I now turn to you with the question of how to extract certain data from the "_massprop" command and assign it to a variable immediately. I am working on an automation task where a cable cross section has to be pulled out on a given 3D polilyne path....
hi, I wish to know how to extrude polylnes to 3D solids in autocad? I am new in cad, and i have around 100 shapes with height but in polylines, so i have to extrude.. i need someone to please tell me how to do this.. i searched online and on utube, but i found only how to draw directly. For m...
Is there any way of aligning one 3D object with other using VBA? Regards, Ramesh.P.K.
I'm trying to access data from 3D solids. I've been working out some rather involved routines to comb through the ACIS data and piece it back together but there must be an easier way. If a face can be identified and assigned a color through a simple click, then surely there is a way to access this...
- 5 replies
- solid edges
- acis
