Showing results for tags '3d models free download'.
    • 3d models free download ×
  1. http://3delicious.net/ This is a really good website to find incredibly detailed models of particular objects for free! The only problem with it is the when you use the search function to find these wonderful models it gives you a Google style list rather than preview of the models. Therefore it...
  2. 3dworld
    3ds max freezing issue
    Hi, I don’t know if anyone else has had this problems too. But here goes: 3ds max 2010 and 2011 both stops responding or starts to lag a lot whenever I press the play button in the animation controls. I have downloaded the latest service packs and hotfixes and still no use. Even the area don...
  3. heartscool
    Mtext Problem
    Hello. Does anyone know a lisp routine which change all MText color to "by layer"? Changing just the entity "MText" doesn't work, it won't apply the same layer color, so I have to edit MText by MText and change to by layer in edition mode one by one. Thanks!!
