Showing results for tags '3d modelling'.
    • 3d modelling ×
Found 7 results
  1. A while back AutoCAD introduced semi-parametric extrusions, you could alter the polyline and the extrusion would update. It's a great feature, but has anyone heard of a way of replacing the polyline profile with a different one? This would be very handy for cabinetmakers who use a variety of profile...
  2. nagendra vr
    Macros in solidworks (Please Help)
    hello EveryoneI wanted to save my sheet metal parts as flat pattern into Dxf file. So I created a macro for this.I have more than 50 files and wanted to run this macro on every file.I tried using Run custom task under task scheduler but its asking for exe file as program Path.Please help me with thi...
  3. Hey everyone i'm new to AutoCAD i need to make an adapter plate and need a bit of help, i'm trying to make two tapered holes in the plate with specific diameters on each end and i have tried cones but i don't know how to put them in the solid rectangle plate, and i have tried extruding circles but i...
  4. Hi I am having a problem with the SWEEP command. I have defined a 2d polyline profile which i want to sweep along a 3D polyline alignment. If I use a basepoint in the middle of the profile (red circle) the function fails, if however I use another point (green square) the command works....
  5. Hi, I'm a construction engineer working with easy architectural design (45%), structural desgin (25%) and building permits for different projects (30%), for example renewal of the plumbing in 4-12 story apartment building (%= the time spent overall). I'm using basic AutoCAD in 2D, applied with d...
  6. Hey Community of AC, i've been working on my thesis, im creating pieces of 3d to hold a servomotor, and ill print it on a 3d printer, will be my first time and i dont want any mistakes since it cost some money, so while creating the piece i've been using a lot of Union-Extrude-Presspulls but using t...
  7. Hi i've got to grips quite well with mesh modelling but i cannot seem to be able to mitigate this shape, a hyperbolic paraboloid in 3D Cad (see attached image)... can anyone give me any guidance on this matter? Thanks Clive
