Showing results for tags '3d modeling annotate'.
    • 3d modeling annotate ×
  1. Is there any way of dimensioning the radius of a cut out made on a 3D solid? The cut edge is not detected as a radius even when orthographic set at 90 deg to the cutting plane. Do I have to use solview/soldraw etc to create 2D versions of the view to dimension? I get the same issues when trying t...
  2. Is it easier to draw out all faces of the 3d object and then merge them together later on or is there a method that allows me to be able to dimension and extrude my object as I work from the 3d space? Say, I created a square and extruded it into a block. Then I want to look at one of the sides...
