Showing results for tags '3d face'.
Hi guys, I need help! How can I EXPLODE a polyface MESH to 3D Face BUT keep original colors. I would appreciate it if you help me to solve the problem. DWG file attached. Kind Regards, Mirzali Jafarov Profile IP Line01.dwg
Very usefull tool to transform 3D Faces To Solid ! ...or a 3D terrain model to a sectionable solid http://www.sharedengineering.com/index.php/13-download/autolisp/20-autolisp-to-transform-3d-faces-to-solid >>> http://www.sharedengineering.com
3d polyline with elevation gained from a 3d face
ewock76 posted a topic in AutoLISP, Visual LISP & DCL
Hi all, I have surveyed some pipes below the ground and I need to represent these as 3d polylines in Autocad below a ground surface model. Is there a routine that will let me add a z value to each vertex along a 3d polyline line which references a 3d face/ground model above to give me a true...- 8 replies
- 3d polyline
- 3d face
