Showing results for tags '3d curve'.
    • 3d curve ×
  1. Hi all, A little new to inventor. Using inventor 2010. I am trying to use a 3d intersection curve to create a sweep. I want to use the 3d curve as the profile but am not able to select it. If the image works the two lines in blue are the 2d sketches that were used to create the 3d...
