Showing results for tags '3d alignment'.
  1. CaptAwesome
    3d Modelling
    Hello and Thank you in advance. I am somewhat new to Autocad 2013 and trying to fumble my way around. I have scoured the net and cant seem to find a clear answer to my questions... Autocad 2013 I need to create an object that is: 733 mm across the top 485 mm across the bottom 526 mm tall the 2 angled sides should have a 80 deg bevel (or chamfer ) to them while the bottom and top both have 75 deg bevel. So more or less its a trapezoid that the top and bottom is beveled to 80 deg while the left and right sides are beveled to 75 deg. Think of the shape of a flower pot if you will. The part will be cut from 5/8" thick wood. This is for a boat that I am attempting to build. Thank you for any help received. I DO NOT want this done for me... though a helping shove would be greatly appreciated.
