Showing results for tags '2d object'.
Hello! I'm working in a dynamic block and I think that I've had to mark or unmark some option in the program because since yesterday I can't use as an initial point of any parameter some central points. I mean, when I try to specify the initial point of any parameter (e.g.: rotation) where the four lines converge, the program tells me that the " 2d object is not valid". I hope I've explained myself right... Can you help me to restore anything that I might have changed? Thank you very much! Warp.dwg
Hi everyone, I want to change a helix to a 2d object as shown in current view (the current view isn't necessarily plan view or front view, etc.) Any suggestions is greatly appreciated
