Dear friends,
i need lisp or macro for ...
Close caps by line in standard mlstyle
If possible help me.......
Regards
mani
Hi
Actually What is the entitiy codes for these points ( start & end ).
Regareds,
Tharwat
Why don't you learn to write them then?
The Styles are stored in the ACAD_MLINESTYLE Dictionary, the cap settings (among other things) are stored in Group 70 of the Style dictionary item.
Example to find which properties are set:
(defun GetMLineStyleProps ( style / dic )
 ;; © Lee Mac  ~  10.06.10
 (if (and (setq dic (dictsearch (namedobjdict) "ACAD_MLINESTYLE"))
          (setq dic (dictsearch (cdr (assoc -1 dic)) style)))
   (GetBits (cdr (assoc 70 dic)))
;; GetBits ~  © Lee Mac
;; Returns the bit combination of a number
(defun GetBits (n / b)
 (if (< 0 n)
   (cons (setq b (expt 2 (fix (/ (log n) (log 2)))))
     (GetBits (- n b))
(GetMLineStyleProps "Standard")
Example of modifying properties...
;;;    1 = Fill on
;;;    2 = Display miters
;;;   16 = Start square end (line) cap
;;;   32 = Start inner arcs cap
;;;   64 = Start round (outer arcs) cap
;;;  256 = End square (line) cap
;;;  512 = End inner arcs cap
;;; 1024 = End round (outer arcs) cap
(defun PutMLineStyleProps ( style code / dic )
   (entmod
     (subst (cons 70 (boole 7 (cdr (assoc 70 dic)) code))
       (assoc 70 dic)
       dic
Hi Mr.Lee
You are using a very advanced programming language which is not known to more than 98 per cent of participators of Cadtutor and nor normal Autolisp Programmers, So would you please make your valued answers more clearer with normal autolisp functions.
In regard to your answer and your example,I really could not deal with most of it, although that I have been using Autolisp for about three years now.
And I found 70 is not belong to start or end of Mlinestyle as in Autocad DXF Help as follows;
Mline group codes
Group code
Description
100
Subclass marker (AcDbMline)
2
String of up to 32 characters. The name of the style used for this mline. An entry for this style must exist in the MLINESTYLE dictionary.
Do not modify this field without also updating the associated entry in the MLINESTYLE dictionary
340
Pointer-handle/ID of MLINESTYLE object
40
Scale factor
70
Justification: 0 = Top; 1 = Zero; 2 = Bottom
71
Flags (bit-coded values):
1 = Has at least one vertex (code 72 is greater than 0)
2 = Closed
4 = Suppress start caps
8 = Suppress end caps
72
Number of vertices
Many Thanks
Tharwat
I'm not sure what you mean by 'Normal AutoLISP functions' I use the functions that I need to perform the task, as for the reference, see here:
http://images.autodesk.com/adsk/files/acad_dxf1.pdf
Page 186 :)
That's ok. But the question is why autocad has different DXF codes as I copied from Autocad Help 2010.
Please clearify it for me.
LWPOLYLINE
ENTITIES Section
MULTILEADER
DXF Reference > ENTITIES Section >
MLINE Expand All
Expand all collapsed sections.
Collapse All
Collapse all expanded sections.
The following group codes apply to mline entities. In addition to the group codes described here, see Common Group Codes for Entities. For information about abbreviations and formatting used in this table, see Formatting Conventions in This Reference.
Mline group codes
Group code
Description
100
2
340
40
Scale factor
70
71
2 = Closed
72
Number of vertices
73
Number of elements in MLINESTYLE definition
10
Start point (in WCS)
DXF: X value; APP: 3D point
20, 30
DXF: Y and Z values of start point (in WCS)
210
Extrusion direction (optional; default = 0, 0, 1)
DXF: X value; APP: 3D vector
220, 230
DXF: Y and Z values of extrusion direction (optional)
11
Vertex coordinates (multiple entries; one entry for each vertex) DXF: X value; APP: 3D point
21, 31
DXF: Y and Z values of vertex coordinates
12
Direction vector of segment starting at this vertex (multiple entries; one for each vertex)
22, 32
DXF: Y and Z values of direction vector of segment starting at this vertex
13
Direction vector of miter at this vertex (multiple entries: one for each vertex)
23, 33
DXF: Y and Z values of direction vector of miter
74
Number of parameters for this element (repeats for each element in segment)
41
Element parameters (repeats based on previous code 74)
75
Number of area fill parameters for this element (repeats for each element in segment)
42
Area fill parameters (repeats based on previous code 75)
The group code 41 parameterization is a list of real values, one real per group code 41. The list may contain zero or more items. The first group code 41 value is the distance from the segment vertex along the miter vector to the point where the line element's path intersects the miter vector. The next group code 41 value is the distance along the line element's path from the point defined by the first group 41 to the actual start of the line element. The next is the distance from the start of the line element to the first break (or cut) in the line element. The successive group code 41 values continue to list the start and stop points of the line element in this segment of the mline. Linetypes do not affect group 41 lists.
The group code 42 parameterization is also a list of real values. Similar to the 41 parameterization, it describes the parameterization of the fill area for this mline segment. The values are interpreted identically to the 41 parameters and when taken as a whole for all line elements in the mline segment, they define the boundary of the fill area for the mline segment.
A common example of the use of the group code 42 mechanism is when an unfilled mline crosses over a filled mline and mledit is used to cause the filled mline to appear unfilled in the crossing area. This would result in two group 42s for each line element in the affected mline segment; one for the fill stop and one for the fill start.
The 2 group codes in mline entities and mlinestyle objects are redundant fields. These groups should not be modified under any circumstances, although it is safe to read them and use their values. The correct fields to modify are as follows:
Mline
The 340 group in the same object, which indicates the proper MLINESTYLE object.
Mlinestyle
The 3 group value in the MLINESTYLE dictionary, which precedes the 350 group that has the handle or entity name of the current mlinestyle.
Please send us your comment about this page
The DXF codes that you provided, were those returned by using 'entget' on an MLine object (I assume).
The MLine Style Settings are stored within the ACAD_MLINESTYLE Dictionary Object, contained in the Name Object Dictionary (namedobjdict).
This Dictionary lists all the MLineStyles defined in a drawing, and so we can search the dictionary for the style we wish to inspect.
The DXF codes as listed on page 186 of the reference I provided are those of the Style Dictionary entry.
Lee
Look at the code I have provided - notice that the argument is not an MLine object, but rather a style name (string).
Look at how I retrieve the DXF codes in my posted code.
Hi Mr Lee
A very nice information. So if I wanted to make an entity for designing Mline Style which code that I have to use for the Start and end of the Mline. (is it the same 70 with flag number)
Many Thanks
Tharwat
For creating an MLine Style you would use the Object reference, but for creating an MLine entity, you use the entity reference.
Mr Lee.
That's great.
Thank you so much for that clarifications, now it is very clear to me.
Your Sincerely
Tharwat
You're welcome - Dictionaries are perhaps a bit more of an advanced part of AutoLISP so don't worry if its a lot to take in :)
Dear Lee,
Actually I am biginner for Lisp..........
How can i use ur code..........
I did't get result....
help me?
Thanks
Regards
mani
Use the code posted in post #5 with the correct stylename and bit code combination for what you want to achieve,
Example for Inner Arcs at start and end:
(PutMLineStyleProps "Standard" (+ 32 512))
:)Hi Lee, I am really very sorry,
becoz my achivement for this one is somthing different.
i am using one of bad route, becoz i don’t have much experience in lisp. but it helps last two years lot lot. (for preparing this taken for 3 month for me).
I know this is very simple lisp for you and others.
My target is (need lisp)
I want a hatch patten like rectangular polyline.
1.draw polyline(user input)
2.offset polyline both side (offset value user input) and erase middle line
3.connect both offset lines by polyline and join all by pedit (end to end & end to end)
5.offset out side 200mm
6.hatch it(only centre)
& ready to next process
See the attachment
Options:
1.offset both side
2.offset any one side
But How i did it in macro,
1.mline(with offset)(with end to end cap)
2.xplode
3.pjoin
4.hatch
if i am using this in to new dwg, need to close mlstyle cap manually every time, thats why i posted this thread
Help me..............
Thanks lot
Mani
See the attachment
Options:
1.offset both side
2.xplode
3.pjoin
4.hatch
Thanks lot
Mani
I'm a beginner as well. I don't care that my codes are simple. It works!
Stick with mline
[color=red] [b](...mline command here...)[/b][/color]
(while (= 1 (getvar "cmdactive"))
 (command pause)
);end while
(command "_explode" "l" "")
(command "_pedit" "m" "p" "" "" "j" "" "")
(command "-hatch" "p" "ansi31" "40" "" "s" "l" "" ""))
MLine to PLine example:
(defun c:m2p ( / *error* EntNext_to_End DOC ELST ENT I MSS OV SS UFLAG VL )
 ;; MLine to PLine  ~  Lee Mac  ~  04.01.10
 (defun *error* ( msg )
   (and ov    (mapcar (function setvar) vl ov))
   (and uflag (vla-EndUndoMark doc))
       (princ (strcat "\n** Error: " msg " **")))
 (defun EntNext_to_End (ent / a)
   (if (setq ent (entnext ent))
     (cons ent (EntNext_to_End ent))
 (setq vl '("CMDECHO" "PEDITACCEPT" "QAFLAGS")
       ov  (mapcar (function getvar) vl) ss (ssadd))
 (mapcar (function setvar) vl '(0 1 0))
 (if (setq i -1 mss (ssget "_:L" '((0 . "MLINE"))))
     (setq uFlag
       (not
         (vla-StartUndoMark
           (setq doc
             (vla-get-ActiveDocument
               (vlax-get-acad-object)
       (lambda ( i )
         (while (setq ent (ssname mss (setq i (1+ i))))
           (setq eLst (entlast) ss (ssadd))
           (vl-cmdf "_.explode" ent)
           (mapcar (function (lambda ( x ) (ssadd x ss)))
             (EntNext_to_End eLst)
           (vl-cmdf "_.pedit" "_M" ss "" "_J" "" "")
           (setq ss nil)
       -1
     (setq uFlag (vla-EndUndoMark doc))
