Efeezy Posted April 29, 2010 Posted April 29, 2010 I Would Like A Custom Polyline. I Haven't Had One In Years... I Would Like The Polyline To Have A Number Or Letter In The Line It Self. I Am Getting So Sick Of Making Wire Tags Gggrrrr.... Quote
The Buzzard Posted April 29, 2010 Posted April 29, 2010 I Would Like A Custom Polyline. I Haven't Had One In Years... I Would Like The Polyline To Have A Number Or Letter In The Line It Self. I Am Getting So Sick Of Making Wire Tags Gggrrrr.... From the AutoCAD help section: Characters from text fonts can be included in linetypes. Linetypes with embedded characters can denote utilities, boundaries, contours, and so on. As with simple linetypes, lines are dynamically drawn as you specify the vertices. Characters embedded in lines are always displayed completely; they are never trimmed. Embedded text characters are associated with a text style in the drawing. Any text styles associated with a linetype must exist in the drawing before you load the linetype. The format for linetypes that include embedded characters is similar to that for simple linetypes in that it is a list of pattern descriptors separated by commas. Character Descriptor Format The format for adding text characters in a linetype description is as follows: ["text",textstylename,scale,rotation,xoffset,yoffset] This format is added as a descriptor to a simple linetype. For example, a linetype called HOT_WATER_SUPPLY is defined as *HOT_WATER_SUPPLY,---- HW ---- HW ---- HW ---- HW ---- HW ---- A,.5,-.2,["HW",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2 This indicates a repeating pattern starting with a dash 0.5 drawing units long, a space 0.2 drawing units long, the characters HW with some scale and placement parameters, and another space 0.2 drawing units long. The text characters come from the text font assigned to the STANDARD text style at a scale of 0.1, a relative rotation of 0 degrees, an X offset of -0.1, and a Y offset of -0.05. This pattern continues for the length of the line, ending with a dash 0.5 drawing units long. The linetype would be displayed as shown below. Notice that the total upstroke length is 0.2 + 0.2 = 0.4 and that the text origin is offset -.01 units in the X direction from the end of the first upstroke. An equivalent linetype would be *HOT_WATER_SUPPLY,---- HW ---- HW ---- HW ---- HW ---- HW ---- A,.5,-.1,["HW",STANDARD,S=.1,R=0.0,X=0.0,Y=-.05],-.3 The total upstroke is still 0.1 + 0.3 = 0.4, but the text origin is not offset in the X direction. Additional information about each field in the character descriptor follows. The values to be used are signed decimal numbers such as 1, -17, and 0.01. text The characters to be used in the linetype. text style name The name of the text style to be used. If no text style is specified, AutoCAD uses the currently defined style. scale S=value. The scale factor to be used for the text style relative to the scale of the linetype. The height of the text style is multiplied by the scale factor. If the height is 0, the value for S=value alone is used as the height. rotation R=value or A=value. R= specifies relative or tangential rotation with respect to the line. A= specifies absolute rotation of the text with respect to the origin; that is, all text has the same rotation regardless of its position relative to the line. The value can be appended with a d for degrees (degrees is the default value), r for radians, or g for grads. If rotation is omitted, 0 relative rotation is used. Rotation is centered between the baseline and the nominal cap height. xoffset X=value. The shift of the text on the X axis of the linetype, which is along the line. If xoffset is omitted or is 0, the text is elaborated with no offset. Use this field to control the distance between the text and the previous pen-up or pen-down stroke. This value is not scaled by the scale factor defined by S=value, but it is scaled to the linetype. yoffset Y=value. The shift of the text in the Y axis of the linetype, which is at a 90-degree angle to the line. If yoffset is omitted or is 0, the text is elaborated with no offset. Use this field to control the vertical alignment of the text with respect to the line. This value is not scaled by the scale factor defined by S=value, but it is scaled to the linetype. Quote
