Combinevalues.LSP [Add/Divide/Multiply/Subtract object values]
I have a really old routine that will add & subtract object values, but I was inspired by this thread to write a new one.
Allows user to combine [Add, Divide, Multiply, Subtract] values of selected objects. User can also change mode (Add, Divide, Multiply, Subtract) at any time. When finished, user is prompted for placement point of MText with final value.
If only Add option used, user has option to average values.
Accepted: Attribute, Civil 3D Point, Land Desktop Point, MText, MultiLeader, Text or typed value.
Call with CombineValues or AV.
Your comments/criticism are greatly appreciated. Enjoy. :)
;;;    CombineValues.lsp v1.2
;;;    Copyright© 04.09.10
;;;    Alan J. Thompson (alanjt)
;;;    Contact: alanjt @ TheSwamp.org, CADTutor.net
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    The following program(s) are provided "as is" and with all faults.
;;;    Alan J. Thompson DOES NOT warrant that the operation of the program(s)
;;;    will be uninterrupted and/or error free.
;;;    Allows user to combine extracted numerical values of selected Attribute,
;;;    Civil 3D Point, Land Desktop Point, MText, MultiLeader, Text or typed value.
;;;    Combine options include: Add, Divide, Multiply, Subtract (can be changed at any time).
;;;    If user only adds values, an option to average is available.
;;;    Upon completion, user is prompted to specify placement point MText with final value.
;;;    Revision History:
;;;    v1.1 (04.11.10) 1. Updated subroutine: AT:ExtractNumbers
;;;    v1.2 (04.13.10) 1. Reworked AT:ExtractNumbers subroutine.
;;;            2. Added subroutine AT:ListSelect to select numbers when multiple exist in string.
;;;            3. If multiple numbers exist in string, user is prompted with list box
;;;               to select each desired number. If multiple numbers are selected, they are
;;;               combined and added to display.
;;;            4. Added CV:StripFormat subroutine, as taken from StripMText 5.0b,
;;;               Copyright© Steve Doman and Joe Burke 2010 (with permission), to avoid any
;;;               issues with extracting numbers out text formatting. (Thank you Joe & Steve)
CombineValues.LSP
Edited by alanjt
  • Like 2
hi sir... your lisp is so great and i preciate it... how to download your lisp? tnx
Thanks and the file is posted below the GIF.
shouldn't the sum be equal to 43.55?
and
(AT:ExtractNumbers "..alan..")
I guess I was thinking about taking the first number, not all. However, since it extracts the numbers into a list, I could easily add an (apply 'f lst) and continue or display a list dialog to select each number. Have to think about that one.
and
Crap, I didn't even think about that one. It even returns 0.0 if fed "..". I may have to rethink Lee's argument about ".3" not being a valid number.
Thanks for looking at it and returning you comments. :)
I can't get to it now, but maybe I can work on it some tonight or tomorrow.
your lisp is great but in my work i need the results rotated at 90 degree and precision like 3.50 if you do so that will be great
Lee already wrote a routine for you that does precisely that.
The precision is left up to the user's settings and if you really must have the text rotated 90°, just rotate your UCS before executing the command.
firest thank's for reply that's right lee wrot routine but your lisp more power because i'm biggner how can i rotate ucs thank's
Type UCS and pick 2 points at a 90° angle.
Command: UCS
Current ucs name:  *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
<World>:
Specify point on X-axis or <Accept>:
Specify point on the XY plane or <Accept>:
alanje that was cool you are genius what about precision how to make ti like 3.50
dear sir,
very good lisp
thx for sharing
I left the precision up to the user's settings (type Units).
dear sir,
very good lisp
thx for sharing
Thanks and you're welcome. :)
Major update:
Solved bug in number extraction.
Formatting is no longer an issue.
If object has multiple numbers, user is given option to choose which values to use.
Major update:
Nice idea to use StripFormat - I think I may need to use it in my TextMath routine - I absolutely detest MText formatting codes! :glare:
Thanks. :)
As soon as I had solved my number extraction issue, I thought about formatting codes. I decided to ask Joe for permission to use the sub from StripMText. Seemed like the best option; he and Steve have spent a lot of time stripping out formatting codes.
  • 1 month later...
another thanks to you. i was thinking of making a similar but simple routine like this but i just found this and a very nice one. you're really great.
You're welcome. Enjoy. :)
  • 5 months later...
Alanjt, I couldn't find the download link below the gif.
Please check. Thx!
