SZLMCL Posted March 28, 2010 Posted March 28, 2010 Hi! I would like to break a polyline in a given dot. All necessary data known to the operation, I cannot make it with VBA. If VBA is not capable to do the operation, then it is possible to make it with Sendcommand? (even running with LISP code from VBA?) For example: My polyline: Me.Hide ThisDrawing.Activate ThisDrawing.Utility.GetEntity objent, varPick, vbCr & "Pick a polyline: " Me.Show The braking point: X=1000 Y=500 Z=0 Try to break (not working): Dim xkoord as Double Dim ykoord as Double xkoord = 1000 ykoord = 500 Set vonallánc = objent.Copy() ThisDrawing.SendCommand "_BREAK" & vbCr Dim kiv As AcadSelectionSet On Error Resume Next Set kiv = ThisDrawing.SelectionSets("SSET") kiv.Delete Set kiv = ThisDrawing.SelectionSets.Add("SSET") kiv.AddItems vonallánc ' kiv.Select vonallánc [/i]' ThisDrawing.SendCommand "F" & vbCr 'Choose Break at First Point ThisDrawing.SendCommand Replace(xkoord, ",", ".") & "," & Replace(ykoord, ",", ".") & vbCr ThisDrawing.SendCommand Replace(xkoord, ",", ".") & "," & Replace(ykoord, ",", ".") & vbCr kiv.Select acSelectionSetPrevious 'kiv.Erase Set vlánc = kiv.Item(0) MsgBox vlánc.Length[/i] Can somebody help to fix this code? Thank you! Quote
SZLMCL Posted April 6, 2010 Author Posted April 6, 2010 Hy I solve the problem, but with for..next is not working (through acSelectionSetPrevious). This code is good to breaking a selected polyline onetime. Public Sub MegTör(ByVal objektum As AcadLWPolyline, ByVal Xkoordináta As Double, ByVal Ykoordináta As Double) Dim s As AcadSelectionSet Dim h As AcadEntity ThisDrawing.SendCommand Chr(28) ThisDrawing.SendCommand Chr(28) ThisDrawing.SendCommand "_BREAK" & vbCr On Error Resume Next ThisDrawing.SelectionSets("TempSSet").Delete Set s = ThisDrawing.SelectionSets.Add("TempSSet") Set h = objektum.Copy s.AddItems h h.Highlight True ThisDrawing.SelectionSets.Item("TempSSet").Select acSelectionSetPrevious ThisDrawing.SendCommand Replace(Xkoordináta, ",", ".") & "," & Replace(Ykoordináta, ",", ".") & ",0" & vbCr ThisDrawing.SendCommand Replace(Xkoordináta, ",", ".") & "," & Replace(Ykoordináta, ",", ".") & ",0" & vbCr h.Highlight False s.Erase s.Delete Application.Update End Sub Quote
Lee Mac Posted April 6, 2010 Posted April 6, 2010 Hey guys, slightly off topic, but you may like to read this thread Quote
SZLMCL Posted April 7, 2010 Author Posted April 7, 2010 Hey guys, slightly off topic, but you may like to read this thread Sorry, I am new here yet. Quote
Lee Mac Posted April 7, 2010 Posted April 7, 2010 Sorry, I am new here yet. Not a problem, just a heads-up Quote
