Thanks for the interest in my Point Manager program Cary, I realise that it didn't quite meet your needs, and so hopefully this will :)
(defun c:attpop (/ *error* StrBrk
                  ALST ATT BNME DDEL DOC FILE LST NL OBJ OFILE PT SPC UFLAG X Y )
 ;; by Lee Mac ~ 01.01.10
 (vl-load-com)
 (defun *error* (msg)
   (and ofile (close ofile))
   (and uflag (vla-EndUndoMark doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (defun StrBrk (str chrc / pos lst)
   (while (setq pos (vl-string-position chrc str))
     (setq lst (cons (substr str 1 pos) lst)
           str (substr str (+ pos 2))))
   (reverse (cons str lst)))
 (if (and (setq bNme (getfiled "Select Block to Insert" (cond (*block_file*) ("")) "dwg"     16))
          (setq file (getfiled "Select Input File"      (cond (*load_file*)  ("")) "txt;csv" 16)))
     (setq uflag (not (vla-StartUndoMark
                        (setq doc (vla-get-ActiveDocument
                                    (vlax-get-acad-object)))))
           spc (if (zerop (vla-get-activespace doc))
                 (if (= (vla-get-mspace doc) :vlax-true)
                   (vla-get-modelspace doc)
                   (vla-get-paperspace doc))
                 (vla-get-modelspace doc)))
     (setq dDel (if (eq ".CSV" (strcase (vl-filename-extension file))) 44 32)
           *block_file* bNme *load_file* file ofile (open file "r"))
     (while (setq nl (read-line ofile))
       (setq lst (cons (StrBrk nl dDel) lst)))
     (setq ofile (close ofile) lst (reverse lst))
     (while (and (setq x  (car lst))
                 (setq pt (getpoint "\nSpecify Point for Block: ")))
       (if (vl-catch-all-error-p
             (setq obj
               (vl-catch-all-apply (function vla-InsertBlock)
                 (list spc (vlax-3D-point pt) bNme 1. 1. 1. 0.))))
         (princ "\n** Error Inserting Block **")
           (setq aLst (vlax-invoke obj 'GetAttributes))
           (while (and (setq y   (car x))
                       (setq att (car aLst)))
             (vla-put-TextString att y)
             (setq x (cdr x) aLst (cdr aLst)))))
       (setq lst (cdr lst)))
     (setq uFlag (vla-EndUndoMark doc))))
 (princ))
Happy New Year!
Lee
  • Replies 48
  • chulse
    27
  • Lee Mac
    21
  • Least
    1
Awesome Lee, Thanks!
I'll be playing with it today (back to work :( )
I am re-building my main template so it couldn't have come at a better time :)
Could I ask you to comment it out a bit like you did that last one for me if you have time?
This is all I have time for:
 ;; --{ Commented Version }--
 (vl-load-com) ;; Load Visual LISP Console
 ;; --{  Error Handler Function  }--
 (defun *error* (msg)  ;; Localised with variables
   (and ofile (close ofile)) ;; If ofile still non-nil, close the open file
   (and uflag (vla-EndUndoMark doc))  ;; If uflag still non-nil, End the Undo Mark.
   (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")  ;; Suppress Cancel messages
       (princ (strcat "\n** Error: " msg " **"))) ;; Print fatal errors
   (princ))
 ;; --{  StrBrk Function  }--
 ;; By Lee Mac  ~  Used to break a string into a list of elements,
 ;;                using a delimiter.
 (if (and
       ;; Block selection
       ;; Data File Selection
     ;; Start the Undo Mark before we proceed uflag = T
           ;; Get the Active Space
     ;; Get the correct delimiter, if CSV, comma, else space.
     (setq dDel (if (eq ".CSV" (vl-filename-extension file)) 44 32)
           ;; Save the defaults for next time, and open the file, ofile = non-nil
     ;; Read the file and break the strings
     ;; Close the file, ofile = nil  and reverse the lst.
     ;; While there are attribs in the list, AND the user has clicked a point
       ;; Catch any errors that occur when inserting the block
             (setq obj
         ;; Else populate the Attribs using the values in the list.
           ;; Get a list of VLA-objects (attribs)
           ;; While there is an attrib and value
             ;; Populate the attribs
       ;; Move onto next item
     ;; End the Undo Mark,  uFlag = nil
 ;; Clean exit
 (princ))
Hope that helps a bit.
Ok, you have inspired me to take this further. I found some functions to populate dynamic properties and I am trying to add them to your code. This is a great start for me that I could have never done myself.
First though, I have changed your code to not ask for the block, but just use the one I need (it will always be the same).
My question is this: my block has only one attribute, but 3 dynamic (linear) properties. Currently, when I add the block, it populates the one attribute with all the values in the list seperated by commas. Is this how it was intended?
What I would like to try is to break up that list to only take the first value for the one attribute, then use the remainder for the other functions?
I will post what I have here in a bit...
Thanks again for your great help!
Wowzer... thanks for picking up on my typo! Missed the strcase when comparing file extensions. I have updated the first post.
I will try to help all I can Cary, but I warn you that I have no experience with Dynamic Blocks... :geek:
Ok, I think I am getting somewhere...
Can you help me make sure I understand this process/have things in the correct order?
I think this is where I am having a problem...
The whole code is attached.
           (setq aLst (vlax-invoke obj 'GetAttributes)) ;;Can I assign this to the attribute tag "TREE#"?
           (while (and (setq TRNUM   (car x))
  ;;;set variables for dynamic values, not sure if this is in the correct place?
  (setq CANOP (cadr x))
  (setq CRZ (caddr x))
  (setq CRD (cadddr x))
 );end and
             (vla-put-TextString att TRNUM)
             ;;(setq x (cdr x) aLst (cdr aLst));;;edited by CH - only one attribute in block
;;;Set Dynamic Properties using "myModifyBk" function
(myModifyBk (list "CRD Radius" CRD))
(myModifyBk (list "CRZ Radius" CRZ))
(myModifyBk (list "Canopy Radius" CANOP))
);end while
 );end progn
tree.lsp
What would I change here (assuming this is the right place) to default to CSV in the dialog box?
I think I figured out one problem - it was that the while loop is now not needed.
It seems to be working now.
So are all your questions answered now? :)
Well,
Would it be possible to prompt for block rotation at the beginning of the routine? (they would all be the same)
Yes,
Instead of giving you the answer straight, I will give you the tools for the job :)
Make a prompt where you want it, and look into the getangle function, perhaps use an IF statement to allow for null input.
I used vla-insertblock to insert your blocks, the arguments are in the list following the function (due to the use of vl-catch-all-apply).
Look up vla-insertblock in the VLIDE help and you can see which of the arguments in the list is the rotation.
Hope this helps!
Lee
Cool, thanks. This has been a huge learning experience for me.
I posted earlier the bit that prompts for the CSV file - do you know how/if the dialog can default to CSV instead of TXT?
This should answer your questions:
(defun c:test ( )
 (getfiled "test" "" "txt;csv" 1)
 (getfiled "test" "" "csv;txt" 1)
 (princ))
I can't find vla-insertblock in the help file anywhere?
  • Type VLIDE at command line
  • Go to File > New File
  • type vla-insertblock
  • It should turn blue, recognising it as a function
  • Double click on it, to highlight the whole word
  • Click on the help symbol (yellowish icon, with blue question mark).
Lee
is it possible to set a default value for the getangle prompt (so the user can just hit enter)?
(and
       ;; Block selection
       (setq bNme "tcot-tree") ;;(getfiled "Select Block to Insert" (cond (*block_file*) ("")) "dwg"     16)) {{removed select block dialog option, force block to TCOT-TREE}}
       (setq file (getfiled "Select Input File"      (cond (*load_file*)  ("")) "csv;txt" 16)) ;; could add "TXT" as file type...
   (setq ROT (getangle "Enter Block Rotation Angle:"))
   );end and
BTW, found the help bits, thanks!
