I've had this on the back burner for a while and decided to finally tackle it. Note we don't use 3dsolids only 3dfaces
Lets say that you have a floor or wall with an intricate design that breaks the finish into 2 different surfaces. Rulesurf can't hit the corners or vertices exactly.
Or you have an irregular shaped polyline to fill with 3DFACEs
Might come in handy ( I know it will for me ) It will take some playing with the routine to get the results right.
Have fun ( not for LT users ) -David
POL-FILL.LSP
Thanks David. I think I found someone who might benefit from it already and have told them to check it out. Is that coincidence or what?
I just have to say THANK YOU!!
So glad I found this forum!
Well you are quite welcome :) -David
David,
Are you still using Autocad R12? Just wondering.
Jenn
David,
Jenn
Yes, I keep a couple Win98SE machines running and use R12 DOS as my main production machine. I have tons of scripts for plotting and things like web publishing that makes my life much easier. -David
Nice....I contract for a CAD co. that still uses R14. It really opens your eyes when you are use to using 2005 and newer. Thanks for the help with the "R" versions.
Thanks. I wrote it after I got tired of getting poor results manually doing things like the seam of the red floor and carpet too quickly. -David
