Area value from a closed polyline in to the clipboard?
Hello everybody!
Is there any lisp or quick way to get the area from a closed polyline in to the clipboard memory?
I want something like this: click on a polyline and then just the press paste in another application.
I'm using AutoCAD Civil 3D 2010, and I disregarded the Civil functions and options from Civil (eg. parcels, styles, etc). This closed polylines are parcels (more than 400 parcels) and I have to check all their area values and paste them in to excel file. The number of the parcels are not consecutive and I didn't use excel data links, etc.
Thank you in advance!
Have you looked into the function EATTEXT.
It will export area data to a number of different file formats (.csv .xls etc)
Thank you NBC for suggestion, but I need to get this area not from one step (Using Data Extraction); i have to make some adjustments in to the drawing (move text, write, rotate, etc. ) before to get the polyline area and these parcels are not correlated with the parcels from excel. These adjustment can take aprox 30 sec to 1 min. and after I finish these I have to check the parcel area in a excel "database". So it cost me some little time (aprox. 1 hour or more) to check only the areas. Until now I've used these methods:
1. click on the polyline -> hit the area field in the properties window (i have to open the Quick Calc to copy the area value :( ) -> paste the value in excel and change the dot with comma to act like a number
2. type area -> two enter -> select object -> copy from command line the area value -> paste the value in excel and change the dot with comma to act like a number
I was looking for a lisp application or another quickly way.
Something like this:
Type the lisp command (I can use a button from AutoCAD CUI) -> select object -> and the command ends but the area value is in the clipboard and eventually convert dot (10042.34) with comma (10042,34) for excel formating cells
Thanks!
This may be a good substitute:
;; Area to Excel Cell  ~  Lee McDonnell (Lee Mac)
;; Copyright © August 2009
(defun c:A2xl (/ *error* xlApp xlCells Row)
 (vl-load-com)
 (defun *error* (msg)
   (ObjRel (list xlApp xlCells))
   (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
     (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (setq xlApp  (vlax-get-or-create-object "Excel.Application")
       xlCells   (vlax-get-property
                   (vlax-get-property
                     (vlax-get-property
                       (vlax-invoke-method
                         (vlax-get-property xlApp 'Workbooks)
                         'Add)
                       'Sheets)
                     'Item 1)
                   'Cells)    Row 1)
 (while
   (and
     (setq ent (car (entsel "\nSelect Object: ")))
       (vlax-property-available-p
         (setq Obj
           (vlax-ename->vla-object ent)) 'Area))
   (vlax-put-property xlCells 'Item row 1
     (rtos
       (vlax-get-property Obj 'Area)))
   (setq Row (1+ Row)))
 (gc) (gc)
 (princ))
(defun ObjRel (lst)
 (mapcar
   (function
     (lambda (x)
       (if (and (eq (type x) 'VLA-OBJECT)
                (not (vlax-object-released-p x)))
         (vl-catch-all-apply
           'vlax-release-object (list x))))) lst))
Hi,
Attached a little DLL which defines a command: COPYAREA
Unzip CopyArea.
From AutoCAD, NETLOAD "CopyToClipBoard.dll".
Type "COPYAREA" and select a polyline, the polyline area is copy to the clipboard as a string (rounded to 2 digits).
The C# code:
using System;
using System.Windows.Forms;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace CopyToClipboard
   public class PolylineArea
       [CommandMethod("COPYAREA")]
       public void CopyArea()
           Document doc = acadApp.DocumentManager.MdiActiveDocument;
           Editor ed = doc.Editor;
           Database db = doc.Database;
           try
               PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: ");
               peo.SetRejectMessage("\nInvalid entity");
               peo.AllowObjectOnLockedLayer = true;
               peo.AllowNone = false;
               peo.AddAllowedClass(typeof(Polyline), true);
               PromptEntityResult per = ed.GetEntity(peo);
               if (per.Status == PromptStatus.OK)
                   ObjectId objId = per.ObjectId;
                   using (Transaction tr = db.TransactionManager.StartTransaction())
                       Polyline pline = (Polyline)tr.GetObject(objId, OpenMode.ForRead);
                       Double area = pline.Area;
                       Clipboard.SetData(DataFormats.Text, Math.Round(area, 2));
           catch (System.Exception ex)
               ed.WriteMessage("\nError: " + ex.Message);
CopyArea.zip
Nice :) Didn't know you knew C# Gile... o:)
I'm newbie, just begining to learn...
Another dll which defines two new LISP functions:
CopyToClipboard copies a string to the clipboard, returns the string if successfull, nil otherwise
TextFromClipboard returns the string stored in the clipboard
Using example (tclaudiu's request):
(defun c:test (/ pl)
 (and
   (setq pl (car (entsel)))
   (setq pl (vlax-ename->vla-object pl))
   (= (vla-get-ObjectName pl) "AcDbPolyline")
   (CopyToClipBoard (rtos (vla-get-Area pl) 2 2))
C# code:
namespace LispExtension
   public class ClipBoard
       // CopyToClipBoard
       // Copies a string to the clipboard
       // Returns the string if successfull, nil otherwise.
       [LispFunction("CopyToClipBoard")]
       public TypedValue CopyToClipBoard(ResultBuffer resbuf)
           try
               TypedValue[] args = resbuf.AsArray();
               string result = (string)args[0].Value;
               Clipboard.SetText(result);
               return new TypedValue((int)LispDataType.Text, result);
           catch
               return new TypedValue((int)LispDataType.Nil);
       // TextFromClipBoard
       // Returns the string from the clipboard or nil
       [LispFunction("TextFromClipBoard")]
       public TypedValue GetClipboard(ResultBuffer resbuf)
           try
               string result = Clipboard.GetData(DataFormats.Text).ToString();
           catch
LispExtension.zip
Thank you very much guys!
Appreciate your attention, I.ve just solve my problem.
Thank you gile for dll and for code. If I want to change the area precision value to 8 digits, should I have C# installed on my machine in order to recompile the dll?
I don't know very much about programming, so initial I've tried to modify the precision area value at the "Clipboard.SetData(DataFormats.Text, Math.Round(area, 2))" in notepad, like a newbie, but I've notice is no use.
Thank you in advance and if this operation (change to 8 digits) doesn't bother you, I will like to ask you if could change it.
Have a nice day!
Hi,
You're welcome.
Yes, to change the DLL you have to recompile it in Visual Studio (google for "visual studio express edition" it's free)
I attach a recompiled DLL (8 digits precision)
But if you're more comfortable with LISP, you can load LispExtension.dll and use the new defined CopyToClipboard LISP function it requieres a string as argument.
If you want a DLL to be automatically loaded at startup, you can see here.
CopyArea2.zip
