Break all lines intersect with each other
dcpanchal_2005
hi,
can any one have lsp routine for break lines intersect with each other..
Thanks
  • Replies 27
  • kyosmith
    9
  • Lee Mac
    5
  • alanjt
    3
  • manirpg
    2
Posted Images
Sounds like bad standards :P
As an alternative, just something I knocked up quickly:
;;; Break All, by Lee McDonnell.  25/07/2009
(defun c:brkAll (/ *error* doc spc ss Objlst Obj iLst Altlst lst)
 (vl-load-com)
 (defun *error* (msg)
   (if doc (vla-EndUndoMark doc))
   (if ov (mapcar 'setvar vl ov))
   (if (not
         (wcmatch
           (strcase msg) "*BREAK,*EXIT*,*CANCEL*"))
     (princ
       (strcat "\n** Error: " msg " **")))
   (princ))
 (setq doc (vla-get-ActiveDocument
             (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (setq vl '("CMDECHO" "OSMODE")
       ov (mapcar 'getvar vl))
 (vla-StartUndoMark doc)
 (or *brk$dis* (setq *brk$dis* 5.))
 (if (setq ss (ssget '((0 . "*LINE,ARC"))))
     (or (not
           (setq tmp
             (getdist
               (strcat "\nSpecify Break Distance <" (rtos *brk$dis* 2 2) "> : "))))
         (setq *brk$dis* tmp))
     (setq Objlst
       (mapcar 'vlax-ename->vla-object
         (vl-remove-if 'listp
           (mapcar 'cadr (ssnamex ss)))))
     (while (setq Obj (car Objlst))
       (foreach iObj (setq Objlst (cdr Objlst))
         (setq iLst
           (cons
             (cons Obj
               (vlax-list->3D-point
                 (vlax-invoke Obj
                   'IntersectWith iObj acExtendNone))) iLst))))
     (mapcar 'setvar vl '(0 0))
     (foreach Int (vl-remove-if-not
                    (function
                      (lambda (x)
                        (vl-consp (cdr x)))) iLst)
       (setq Obj (car Int))
       (foreach Pt (cdr Int)
         (and Altlst (setq lst Altlst))
         (if (not (setq bDis (vlax-curve-getDistatPoint Obj Pt)))
           (while (and (not bDis) lst)
             (setq bDis (vlax-curve-getDistatPoint (setq Obj (car lst)) Pt)
                   lst (cdr lst))))
         (if bDis
             (or (setq bPt1 (vlax-curve-getPointatDist Obj
                              (+ bDis (/ *brk$dis* 2.))))
                 (setq bPt1 (vlax-curve-getEndPoint Obj)))
             (or (setq bPt2 (vlax-curve-getPointatDist Obj
                              (- bDis (/ *brk$dis* 2.))))
                 (setq bPt2 (vlax-curve-getStartPoint Obj)))
             (command "_.Break"
               (list (vlax-vla-object->ename Obj) pt) "_F" bPt1 bPt2)
             (setq AltLst (cons (vlax-ename->vla-object (entlast)) AltLst)))))))
   (princ "\n** Nothing Selected **"))
 (princ))
(defun vlax-list->3D-point (lst)
 (if lst
   (cons (list (car lst) (cadr lst) (caddr lst))
         (vlax-list->3D-point (cdddr lst)))))
  • 4 months later...
Very cool routine!!!
Questions:
1. Is it possible to specify that either vertical or horizontal lines are broken based on user input?
2. Is it possible to break only lines that completely cross each other while ignoring lines that just touch without crossing, such as lines drawn using the perpendicular osnap?
Thank you.
Ray
Questions:
Thank you.
Ray
Thanks Ray,
I should think both are possible, if I had a bit more time, but I shall see what I can do.
In the mean time, check this out - someone who spent a bit more time on the same kind of routine...
http://www.theswamp.org/index.php?topic=10370.0
  • 4 months later...
Questions:
Thank you.
Ray
thats exactly what i need!
some one can help ?please!
:cry:
yeah but the macro on the link does not break only the vertical lines that crosses a horizontal one
and it also breaks the perpendicular lines to
the thing i need : select a bunch of lines (many lines) and then break only the vertical lines that crosses a horizontal one
ive already saw this man...
ok thats not exactly what i need...
i will tell you all :
i have a lisp that create lines with an arrow at its endpoint:
here is the code
(defun C:FLUXO (/ PT ENT PT1 PT2 ANG PTA PTB TP ARANG ARROW Slist OK FIM )
(setq Pt1 (getpoint "\nSpecify first point: "))
(initget 1)
(setq Pt2 (getpoint Pt1 "\nSpecify second point: "))
(command "._line" Pt1 Pt2 "")
(setq old_lay (getvar "clayer"))
(command "layer" "set" "0" "")
(setq setinha  (entlast)
       ARANG (angle PT1 PT2)
FIM     (polar PT2 ARANG -3) ; fim da seta
ARROW (list (cons 0 "LWPOLYLINE")
     (cons 100 "AcDbEntity")
     (cons 8 (getvar "clayer"))
     (cons 100 "AcDbPolyline")
     (cons 90 3)
     (cons 70 128)
     (cons 38 0)
     (cons 39 0)
     (cons 10 PT2)
     (cons 40 0)
     (cons 41 1.5)
     (cons 42 0)
     (cons 10 FIM)
     (cons 40 0)
     (cons 41 0)
     (cons 42 0)
     (cons 40 0)
     (cons 41 0)
     (cons 42 0)
 (entmake ARROW)
(command "layer" "set" old_lay "")
(setq
 SList (ssadd (entlast))    ; begin a selection set of center line
 OK T      ; set flag
) ;_ closes setq
(while OK      ; while still drawing lines
 (setq Pt1 (getvar "LastPoint"))   ; used for next line command
 (setq Pt2 (getpoint Pt1 "\nSpecify next point: ")) ; get next point
 (if Pt2      ; if a point was chosen
  (progn      ; then...
   (command "._line" Pt1 Pt2 "")   ; draw next line
     (cons 90 3)
     (cons 70 128)
     (cons 38 0)
     (cons 39 0)
     (cons 10 PT2)
     (cons 40 0)
     (cons 41 1.5)
     (cons 42 0)
     (cons 10 FIM)
     (cons 40 0)
     (cons 41 0)
     (cons 42 0)
     (cons 40 0)
     (cons 41 0)
     (cons 42 0)
 (entmake ARROW)
   (setq SList (ssadd (entlast) SList))
   (setq OK NIL)
my lisp coding sucks so i modified anothers person code to do that.
i need to draw the lines with the arrows and then break the vertical ones that intercept the horizontal lines like this :
Try these lisps from my old code library
(don't remember how it works, sorry)
BreakVert.lsp
;;break vertical lines only
(defun C:BreakVert(/ copya ent_list hlines hobjs points tmp vlines vobjs)
;;get all lines entity lists
(setq ent_list (mapcar 'entget
 (mapcar 'cadr
 (ssnamex (ssget (list '(0 . "LINE"))))))))
;;vertical lines
(setq vlines (mapcar 'cdr
      (mapcar 'car
       (vl-remove-if-not
 (function (lambda(x)
      (equal (car (cdr (assoc 10 x)))
(car (cdr (assoc 11 x))) 0.001))) ent_list))))
;;horizontal lines
(setq hlines (mapcar 'cdr
      (mapcar 'car
       (vl-remove-if-not
      (equal (cadr (cdr (assoc 10 x)))
      (cadr (cdr (assoc 11 x))) 0.001))) ent_list))))
;;convert to vla-objects
(setq vobjs (mapcar 'vlax-ename->vla-object vlines))
(setq hobjs (mapcar 'vlax-ename->vla-object hlines))
(foreach a vobjs
 (setq tmp (list (vlax-curve-getstartpoint a)
   (vlax-curve-getendpoint a))
 (foreach b hobjs
   (setq points (vlax-invoke a 'Intersectwith b 0))
   (if (= 3 (length points));two perpendicular lines has just one intersection
     (setq tmp (cons points tmp ))))
 (if (> (length tmp) 2)
     (setq tmp (vl-sort tmp (function (lambda(x y)
    (< (vlax-curve-getparamatpoint a x)
       (vlax-curve-getparamatpoint a y))))))
     (vla-put-startpoint a (vlax-3d-point (car tmp)))
     (vla-put-endpoint a (vlax-3d-point (cadr tmp)))
     (setq tmp (cdr tmp))
     (repeat (1- (length  tmp))
(setq copya (vla-copy a))
(vla-put-startpoint copya (vlax-3d-point (car tmp)))
(vla-put-endpoint copya (vlax-3d-point (cadr tmp)))
(setq tmp (cdr tmp)))))
BreakHorz.lsp
;;break horizontal lines only
(defun C:BreakHorz(/ copya ent_list hlines hobjs points tmp vlines vobjs)
 (mapcar 'cadr
;;vertical lines
      (mapcar 'car
       (vl-remove-if-not
;;horizontal lines
      (mapcar 'car
       (vl-remove-if-not
(foreach a hobjs
 (foreach b vobjs
~'J'~
fixo how to set an offset distance in that vertical code?
CAB: i need the perpendicular snaps intact. the "BreakWith" breaks it to
Fixo:
i added this line to the code
(setq pt1 (polar (car tmp) 1.57079633  -2))
(setq pt2 (polar (cadr tmp) 4.71238898 -2))
(vla-put-startpoint copya (vlax-3d-point pt1))
(vla-put-endpoint copya (vlax-3d-point pt2))
but it also breaks the perpendicular snaps
The ObjectSnap issue is something else entirely, that functionality relies on just the entity data - bear in mind that AutoCAD doesn't know that the line is only broken for clarity - AutoCAD will treat them as two separate lines. You are asking too much.
If you wanted to keep all the snaps in tact, you would need to use a wipeout or similar.
can anyone help me please!!
LoL
I would say several are.
LoL
man im just asking for help! :(
i really need this and dont know how to do
