Hi All
I am trying to use the vla-get-promptstring for an attribute definition
;vlax-safearray->list (getattribute) method
However the response i recieve is
error: ActiveX Server returned the error: unknown name:
Any thoughts
Cheers
Ollie
You will have to approach it this way Ollie to get the Prompt String:
(defun getpmt (blk)
 (if (tblsearch "BLOCK" blk)
   (vlax-for Obj (vla-item
                   (vla-get-Blocks
                     (vla-get-Activedocument
                       (vlax-get-acad-object))) blk)
     (if (eq "AcDbAttributeDefinition"
             (vla-get-ObjectName Obj))
       (setq pmt (vla-get-PromptString Obj)))))
 pmt)
Once again Lee thanks.
Can't believe how complicated that is in comparison to the grab properties for the other members
Ollie
No problem Ollie.
Bear in mind that the above will cycle through every attribute definition (if there is more than one) - and so you may need to filter it for attribute tagstring also. :thumbsup:
Lee
