I am having problems due to my file size. I have had to turn off auto save because if it tries to save the same time I am trying to do another function my system will lock up and go into fatal error and I loose all I have done from my last manual quick save. I try to remember to do it before I do anything that will cause the fatal error ( which are mainly from adding Xref's and trying to orbit my models) but I find that I don't as much as I would wish.
What I am asking is if it is possible to do a Save with a lisp if an orbit or and Xref command is called first.
I hope this is possible but if it is not I will just have to get better at saving before I do either of these.
Thanks
NH3man!
Thanks
NH3man!
(defun C:so()
 (command"save" "")
 (command"orbit")
The only solution I can think of at the moment would be to create functins similar to the one above.
I'm not sure how you would replace crt+middle mouse to this though
Ollie
I would suggest reactors being a solution
Im not sure if a quick save could work, a bit of trial and error.
here is an example, for any dims to go to dim layer
(vl-load-com)
(vlr-command-reactor nil '
  ((:vlr-commandWillStart . startCommand)
  (:vlr-commandEnded . endcancelCommand)
  (:vlr-commandCancelled . endcancelCommand))
 ); end vlr-command-reactor
(defun startCommand (calling-reactor startcommandInfo)
(if (= 1 (getvar "dimlfac"))
 (setvar "dimclrt" 2)
 (setvar "dimclrt" 3)
 (if (wcmatch (car startcommandInfo) "DIM*")
 (setq dimOldLayer (getvar "CLAYER"))
 (setvar "CLAYER" "dim"))
   ); end if
);defun
(defun endcancelCommand (calling-reactor endcommandInfo)
(if(wcmatch (car endcommandInfo)"DIM*")
  (if (= dimoldlayer "dim")
   (setvar "CLAYER" "yellow")
   (setvar "CLAYER" dimoldlayer)
   ); end if
);defun
I agree, a reactor would be a good call - hopefully the system won't freeze when the quick save is called.
It would have to be through VL however, as command calls do not mix with reactors. :geek:
Lee
Depending on how orbit and xref are called in your setup, you could also use undefine and a new (defun) of the command. -David
Not sure if this would work for you?
(defun c:ReON ()
 (vl-load-com)
 (if (not *Save:React*)
     (setq *Save:React*
         (list
           (cons :vlr-CommandWillStart 'StrtComm))))
     (princ "\n<< Reactor Initiated >>")))
 (princ))
(defun StrtComm (React Args / *doc)
 (if (vl-position
       (strcase (car Args))
         '("3DORBIT"))  ; <<-- Populate Commands Here
     (setq *doc
       (vla-get-ActiveDocument
         (vlax-get-acad-object)))
     (if (not (eq "" (vla-get-FullName *doc)))
       (vla-save *doc)
       (vla-saveas *doc
         (strcat
           (vla-get-Path *doc) "\\"
             (vla-get-name *doc))))))
 (princ))
(defun c:ReOFF ()
 (if *Save:React*
     (vlr-remove *Save:React*)
     (setq *Save:React* nil)
     (princ "\n<< Reactor Deactivated >>")))
 (princ))
Nice idear of being able to turn it off, instead of always on...
Easier than rebooting AutoCAD every time :P
Yer true, Ive always just let them run in the back ground not noticing them aye.
Also while you here,
What is the funtion to organise a list in order, I know their is one for words, but is their for numbers?
vl-sort can sort a list using a predicate function, hence:
(setq lst '(3 5 2 4 1))
(vl-sort lst
 (function
   (lambda (x y) (< x y))))
will return:
(1 2 3 4 5)
Lee
I tried it Lee but how do I know it does a save. I don't see it in the command line. Is it an auto function that is not displayed?
Yer, reactors work in the back ground, with no input/output from/to user.
Check the file, it will say when it was last saved
As flower says, you won't visually see the results, as I have used the VL save method - so it won't show at the command line. :)
Lee
That is great Lee. You will save me and I won't even know it till I go to reopen and all my work is still there. Thank you!
No probs :)
Switch the reactor on and off using ReOn and ReOff, and you can use this if you like to give you some assurance that it has worked:
(defun c:ReON ()
 (vl-load-com)
     (setq *Save:React*
         (list
 (princ))
 (if (vl-position
     (setq *doc
       (vla-save *doc)
       (vla-saveas *doc
         (strcat
     (princ "\n** Document Saved **\n")))
 (princ))
(defun c:ReOFF ()
 (if *Save:React*
 (princ))
